Changing the user schema for a user on a sde database
2463
04-28-2017 08:55 AM
by Anonymous User
Not applicable
Hello, basically what I want to do is have a user create a feature class in an sde database and have their user schema be dbo (or other standardized name) without being granted system admin. Currently when a user tries to create a feature class it names it 'database."domain/user".dataset. Is there anyway for the created dataset to be 'datbase.dbo.dataset' and be anonymous? A couple details and things that have been tried:
  • SDE database is a Sql Server
  • Have tried adjusting user mapping in Sql Server Manager to have the dbo default schema
  • Have tried setting their role as db_owner
  • Have tried unchecking 'sde owned schema' when creating the enterprise database
  • Again, problem is not creating the data it is adjusting the schema to display as described above
Any ideas or need more info? Thanks!
Reply
ManviLather1
Hello,
--We can save the data in "dbo schema" without granting the user "sysadmin" server role by changing the database owner using the following command:
EXEC sp_changedbowner 'name';
(You can confirm the owner of the geodatabase using the command: sp_helpdb; )
--There can be only one database owner.
Reply
Asrujit_SenGupta
MVP Regular Contributor
You should check the below link before deciding on what to do:
A comparison of geodatabase owners in SQL Server—Help | ArcGIS Desktop
Specially check the Pros and Cons mentioned under the "Which user should own the geodatabase?" part in that link
Reply
