Change Portal Name from Machine Name to DNS Name
882
11-03-2023 06:07 AM
olamendel
I want to chang my server domain name from "machinename.domain.com" to "machinename.newdomain.com"
How can i change my domain name by saving my all portal content
WebContex-URL ? WebAdapytors ?
Any Experience in this matter?
I'm using ArcGIS 10.8
MarceloMarques
Need to change domain name of ArcGIS Enterprise (S... - Esri Community
Organization URL—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
"If you need to change the hostname in your organization URL, contact Esri Professional Services or another trusted consulting partner for guidance."
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
ArchitSrivastava
Hello @olamendel ,
I concur with what @MarceloMarques suggested. To add to that my recommendation (based on personal experience) when changing machine names is that you have to do a fresh install of the software. Why?
The reason is that ArcGIS Enterprise writes the machine name to deep parts of its configuration.
You can change the name of an ArcGIS Server node but not Portal, so you will be stuck with that at least
For ArcGIS Server : https://enterprise.arcgis.com/en/server/latest/administer/windows/common-problems-and-solutions.htm#...
Hope it helps!
-Archit
