Can you upgrade the JRE independent of the ArcGIS Server?
549
06-10-2021 05:49 PM
CharlesColeman
New Contributor II
All,
I'm supporting version 10.8.1 ArcGIS Servers on a government project. There is a new security requirement that all JREs must be of version 11.07 or greater. The serverinfo command shows that 10.8.1 uses the 11.06 JRE.
Is there a way to update the JRE without upgrading the ArcGIS Server? The wheels of government run slow, and I had just upgraded our servers to 10.8.1, which required many meetings and document writing. It would be nice if I could just upgrade the JRE alone.
Any help on this issue would be greatly appreciated.
Thanks in advance,
Chuck
Scott_Tansley
MVP Regular Contributor
Not if you want to remain supported.  Recommend you use 10.9 and see what the JRE is there.  It's a black box and shouldn't be tinkered with.  🙂
Scott Tansley
https://www.linkedin.com/in/scotttansley/
Scott_Tansley
Scott Tansley
