can't publish services to ArcGIS Server
5520
9
01-27-2018 04:24 PM
SaraEL_MALKI
Hi guys,
I've already workd with ArcServer for years, and Now I've changed my laptop and needed to install the softwares all over again,
I'm using a geodatabase (PostgreSQL), and succeded to connect to it as an enterprise geodatabase,
successfully connected to ArcGIS Server and registred it my geodatabase.
(working with ArcGIS 10.2)
but once I wanted to publish a map service, an error is displayed,when trying to publish a service
I have tried to google the error but none of the tricks helped,
Error: Packaging succeeded, but publishing failed. ERROR: unable to connect to publishing tools serv...  because I've already gone through these stuffs, I don't remeber at all having to create roles in the server manager as that links suggest,
when I tried to give all the permissions to arcgisserver directory,
It displayed that error: (which is about that an error occured while applying the changes. access denied) when I clicked continue it gives the full control to the folder (data-store, directories-logs)
access denied
I tried to restart the publishing service but it failed showing that arror:
restarting Publishing service
and just then I discovered that all the system services of the server are empty of tools:
empty services
I am stuck right now, please if you pass by here tag someone who can help me in this, because the docs contains a lot of text meanwhile I need sceenshots to explain me the possible solutions.
(I am on local machine, so my server is localhost & I've configured the web adaptor with the server)
Derek Law‌ Rebecca Strauch, GISP Robert Scheitlin, GISP
DerekLaw
Esri Esteemed Contributor
Hi Sara,
If you've tried the various troubleshooting suggestions in the Esri KB doc #000013246 (you referenced),
and were unable to address your problem, I doubt that anyone on the forums can help further.
When you attempted to restart your GP publishing service and got the ArcGIS Server error message, was there a log file in the location specified? c:\arcgisserver\logs\SIG-SARA\errorreports
I suggest you contact Esri Tech Support so they can help look into your issue further.
Hope this helps,
SaraEL_MALKI
Publishing service error
for the  exception information it says: "The thread tried to read from a virtual address or write to a virtual address for which it does not have appropriate access"
I'm working on localhost, in a windows admin account:
I don't know which access I can give ? and how to do so ?
shan_sarkar
Sara,
Did you try logging in the Admin REST page and then try to restart the Publishing GP service? Do you still receive the same error?
~S
~Shan
RandallWilliams
What OS are you working with? Is ArcGIS server installed on the same machine as ArcGIS Desktop?
SaraEL_MALKI
I am on windows 7 pro.
Yes on the same machine. When I have installed ArcGIS server it created an other session and I made it an administrator
RandallWilliams
Upgrade to 10.2.2 and apply this patch:
https://support.esri.com/en/download/7576
I'm betting that your new machine has the Microsoft patch that breaks GP on Windows 7 and 2008.
SaraEL_MALKI
Thank you mister Williams;
Will the problem be solved if I upgrade to windows 10 ?
RandallWilliams
Assuming that this is indeed the same issue, yes. However, I'd still update to 10.2.2 at a minimum, preferably a more recent version that's fully supported.
ThomasSteudel1
Is this patch for ArcGIS Version 10.2.2 working?
Our Software-Provider told me last week, that we have to upgrade to 10.4 before i can use the patch. So now i am not able to publish anything.... Even publishing the .sd files via the ArcGIS Server Manager does not work. The "uploading" process takes ages - so i had to stop it after 10 minutes.
Is there another way to publish my services? Thanks alot and thanks for the patch-solution!
