Can't display layers in Enterprise Sites, till REST services are opened
937
02-01-2020 09:26 AM
AHMEDSHEHATA1
Hi Everyone,
I'm experiencing an issue with ArcGIS Enterprise sites 10.7, in particular the embedded web map element.
The layers are showing only when displayed in a standalone web map/app, but when the web map is added as an element to a site, layers don't show up. I have to open the REST services of the federated server, login and then layers show up in the site. However, if a web app (containing the same web map) is added to the sites in iframe element, layers show up normally.
I thought it would be a certificate issue, hence I made sure the CA-signed and root certificates are installed in the machine and imported in the server and portal SSL certificates. Also, I created a domain certificate and imported it for the web adaptor <> server & portal internal communication, but no joy!
Environment:
Server and Portal and WA10.7
Same machine
Machine is publicly accessible
Any ideas?
Ahmed
jill_es
Hi Ahmad - the behavior you are encountering is a known defect, BUG-000127013: Secure services are not rendering on ArcGIS Enterprise Sites.  This bug is currently marked as "in product plan".  You can subscribe to this defect here; doing so can help us understand the demand behind this bug.
KellySt__John
Hello Jill.  Referring to this bug status, am I reading correctly that this bug isn't fixed unless we jump to Portal 10.8.1?
jill_es
Hi Kelly St. John, you are correct - this bug won't be fixed until ArcGIS Enterprise 10.8.1.
