Can i use Google maps (satellite basemap) as my basemap
6775
02-26-2016 10:10 AM
MarcoAmaya2
In much places the ESRI basemaps are very outdate, is there any way to use google maps like my basemaps in my arcgis server services and my AGOL services.
Regards
ChristopherSchreiber
Occasional Contributor II
Marco,
Using a Google map in this way violates Google's TOS.
Specifically, this part (10.4e):
  1. No use of Content with a non-Google map. You must not use the Content in a Maps API Implementation that contains a non-Google map.
Link: Google Maps/Google Earth APIs Terms of Service  |  Google Maps APIs  |  Google Developers
Sorry to bring bad news, hopefully Esri can work something out with Google.
Chris
AdrianWelsh
MVP Notable Contributor
I believe this is (or used to be) a very touchy question. For the most, this will depend on where you live and how Google has their maps contracted. In some places, the local agency (in my case, my local State agency) will have contracted Google Imagery that you can use in ArcGIS Online as a basemap.
In other cases, there appears to be several different ways of obtaining this, though they don't all appear to work.
This service appeared to work at one point but it seems like it was last updated about 3.5 years ago:
http://www.arcgis.com/home/item.html?id=a8f78cc6adea48cb8e962d7e36b9d010
There was a question in the developers forum (using JavaScript) about this that has some suggestions with possible solutions:
Add Google Basemap via Javascript
There are a few solutions listed at this blog post:
My Adventure with Google Maps in ArcMap | SoCalGIS.org
In any case, you might have to look around to see if there are any local agencies that have obtained Google's Imagery or try some of these linked suggestions.
Marco,
Chris
