Can a Desktop 10.2.2 user make a Database Connection to ArcServer 10.3.1
4686
14
11-20-2015 11:01 AM
PaulHuffman
After a long and painful process of upgrading from Server 9.3.1 to Server 10.3.1 https://community.esri.com/thread/161853 because our Desktop 10.2.2 users could not connect to Server 9.3.1 https://community.esri.com/thread/165892,  now I can't figure out a way to make a database connection from Desktop 10.2.2 to Server 10.3.1.  Are my 10.2.2 users stuck between server versions?
RebeccaStrauch__GISP
I my opinion, if not trying to edit and or resync, Fgdb work better.  For imagery, you want to look at What is a mosaic dataset?—Help | ArcGIS for Desktop       if you have the Image Server extension you even have more options.  However, ArcSDE still has many uses, especially if trying to use some of the new mobile app options and check-out and check-in.  But for MapServices, in my opinion, a file gdb is the way to go.
PaulHuffman
I have a user with Desktop 10.3.1 that tried to connect to my new 10.3.1 geodatabases,  but got "Failed to connect to the specified server. Do you want to continue? Connection was attempted with an older version of SQL Server client communications software that was not compatible withe the SQL Server database server."  Does this user with a Windows 7 PC really need to go find an updated driver from MS to communicate?
PaulHuffman
Jeez, my power user says that he managed to find an updated SQL communications driver from MS, and now his connection from Desktop 10.3.1 to 10.3.1 Enterprise geodatabase works.  Is that crazy? Now what about connections from Desktop 10.2.2?
PaulHuffman
We were getting this error trying to connect 10.3.1. and 10.2.2 Desktop to Server 10.3.1.  Once we installed the new SQLNATIVEClient2012 driver, we are back in business.  We are telling our users "You must install this Microsoft installation file with an account with administrative privileges’ on your machine. Restart your machine after installation."   I'll try to find the link again.
PaulHuffman
