Cached Tiles load slow occassionally
609
06-18-2014 11:21 AM
by Anonymous User
Not applicable
Original User: gnanicys
I have a cached basemap in use with my Viewer for Flex 3.5 application and the draw speed performance is rather unpredictable.  Even if no one else is using the application with the basemap, it will stall drawing.  Sometimes it is perfectly fine.  The issue mainly occurs when zooming in or out or panning around at the speed I normally do for any other mapping applications.  When I try googling for help on slow basemap loading I find I am supposed to cache it, but it is, it just seems to serve slowly. What is causing this issue, what to check, what am I missing?
Here are some additional information and specs to help me guide me down a way to prevent this from happening.
[ATTACH=CONFIG]34696[/ATTACH][ATTACH=CONFIG]34697[/ATTACH][ATTACH=CONFIG]34698[/ATTACH]
Service Type: Cached (fused)
File Format: Mixed Compression: 75
Restriction: Sub-layers can't be turned on or off
Cache Scales at 96 DPI:
Coordinate System:
Projection: Mercator_Auxiliary_Sphere
Geographic Coordinate System: GCS_WGS_1984
Server Specs:
Processor: Intel(R) Xeon(R) CPU E5-2667 0@2.9GHz
RAM: 16GB
Windows Server 2008 R2 Standard
64 bit OS
Wondering if possibly if performance is affected since SQL continues to take up more memory even after setting the max on it.
