Auto-update map service in ArcGIS 10.1
2179
05-14-2013 01:33 AM
SunilPalkar
Hello All,
I just want to know that is it possible to publish service from certain interval (say 2 hour)
Reason: I am using ArcGIS Server & DT 10.1 and Sql Server 2008 R 2. My data base is updating hourly and I am unable to view updated points in my map (those points are coming in.mxd but after overwriting service I am able to view those points on map)
It is impossible to overwrite service every hour. I researched on Google and Web help (I have seen ArcGIS ADMIN API + ArcPy+FAQ) but unable to find solution for this problem even ESRI support people closed my ticket 😞
Therefore, any help will be great!
Thanks in advance : )
divyamgulati1
Hi Sunil
Anthony is right. Changes to your data should be automatically reflected to your service. Anyway what you can do is publish .mxd which references the data in SDE using a python script. You can run the overwrite map service py script.
Refer this url:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00540000001r000000
You can automate the running of this script in every 2 hours using windows task scheduler.
AnthonyGiles
Honored Contributor
Sunil,
Could you explain in more detail why you need to overwrite your map service to see changes made to the data in the database. Changes to your data should be automatically reflected in your web applications.
Regards
Anthony
divyamgulati1
Hi Sunil
Refer this url:
SunilPalkar
@divyamg  Thanks for your link. My problem is resolved : ) .
Sorry for my late reply.. thanks once again : )
Hi Sunil
Refer this url:
