Auto populate value of primary/key fields of parent feature layers into fields of destination feature layers
1267
10-07-2020 05:51 PM
AnjulPandey
Solution Environment:
Portal for ArcGIS 10.6.1 (Fresh Build)
ArcGIS Server 10.6.1 Standard Edition
Context and Problem statement:
I am using COTS edit widget in WAB enterprise portal application. There are requirements to edit related records from feature layers with one to many relationship.
Goal:  I want to auto populate value of primary/key fields F1 & F2 of parent feature layers into fields of destination feature layers while editing feature using Edit Widget in WAB Portal.
by Anonymous User
Not applicable
Hi Anjul,
Have you tried using the Smart Editor widget? Smart Editor widget—Portal for ArcGIS | Documentation for ArcGIS Enterprise
This widget allows you to access and edit the related tables for feature layers, extending the functionality of the standard Edit widget.
I came across another GeoNet post that discusses the auto-populate functionality further: https://community.esri.com/thread/221152-auto-populate-id-using-related-tables-in-smart-editor
Hope this helps!
-Calvin
AnjulPandey
Hi Calvin,
Thanks for prompt response , I am using edit widget to provide Cut, reshape & snapping tool functionality as this tools are not available in Smart Editor?
