ArcMap symbols are not shown in ArcGIS Server Map Service
1392
11-27-2018 05:05 AM
AlessandroValra
I have problems with a simbology in a linear layer.
I defined the symbology using the "Categories -> Unique values, many fields" strategy in ArcMap.
One of the two fields I am using is named STYLE and has only two values: VERTICAL and DEVIATED.
VERTICAL defines lines which have vertical geometries, i.e. coincident XY coordinates and different Z coordinates.
I defined the style in a way that is working fine in ArcMap, but after I published the mxd with this layer and this symbology to ArcGIS Server as a Map Service, the VERTICAL lines are not displayed.
Here is how I defined the symbology (e.g. for values Dry, VERTICAL):
In ArcMap I zoom in to a "Dry, VERTICAL" feature and I see it correctly.
From ArcGIS Online I visualize my Map Service and zoom in the same zone but I can't see the feature (only a label is displayed but this stays in another layer):
Also, look at the difference in the legend from AGOL:
Looking at the service details in REST, here is what I see:
Drawing Info:
Renderer:
Unique Value Renderer:
Field 1: Edison.DBO.ITA_WELLS.RESULT
Field 2: Edison.DBO.ITA_WELLS.STYLE
Field 3: null
Field Delimiter:
Default Symbol:
N/A
Default Label: null
UniqueValueInfos:
      • Value: Dry,DEVIATED
        Label: Dry, DEVIATED
        Description:
        Symbol:
Style: esriSLSSolid
Color: [0, 0, 0, 255]
Width: 1
      • Value: Dry,VERTICAL
        Label: Dry, VERTICAL
        Description:
        Symbol:
Style: esriSLSSolid
Width: 18
The version of ArcMap is 10.6, that of ArcGIS Server is 10.6.
Anything I am missing?
Yuriko
Hi Alessandro,
There is an ESRI symbology style set called ESRI_Optimized which is optimized for web display--not all symbology available in ArcMap can be rendered on a web map service.
Optimizing map symbols for performance—Help | ArcGIS for Desktop
Maybe the above read will help?
AlessandroValra
Yuriko Hashimoto‌ thanks for the hint.
I don't know if it's a problema related to the style I am using: in facts, I can see the same symbols showing up properly when lines are not vertical both in desktiop and server.
I am guessing is another bug related to ArcGIS dealing with vertical geometries (as in my other thread).
Of course, I will give the ESRI_Optimized style a try when I can and come back if I discover something new.
Thanks!
