ArcMap 10.7 fails to drag\drop services and ends up with “couldn’t add the specified data object to the map” warning,
472
05-13-2019 07:02 AM
JamalNUMAN
Legendary Contributor
Despite the fact that services can be dragged and dropped into ArcMap 10.6.1 (or earlier version), the ArcMap 10.7 fails and ends up with “couldn’t add the specified data object to the map” warning.
What could be the issue here?
You can tried services available here:
https://parcels.geomolg.ps:6443/arcgis/rest/services
thanks
Jamal
Jamal Numan
by Anonymous User
Not applicable
Hi Jamal,
I'm able to add services from ArcGIS Server 10.6.1 by dragging and dropping without the error in ArcMap 10.7: 05.13.2019-10.38.59
Does this happen with any other servers or just this one? Does it happen with a publisher or admin connection?
Also, sharing your REST URL publicly for testing presents some security risks, though in general this community is full of good people!
Best,
Lauren
MichaelVolz
Esteemed Contributor
Lauren:
Are you bringing services from AGOL or other portal into ArcMap?  Or are you bringing services from a standalone AGS environment?
by Anonymous User
Not applicable
Hi Michael,
I'm bringing in map services and feature service from a AGS Server 10.6.1 environment not from Portal or ArcGIS Online, as shown in the video. Are you seeing the same behavior as Jamal in 10.7?
