Arcmap 10.5.1 ORA-12154: TNS:could not resolve the connect identifier specifiedNo extended error
6342
7
01-03-2019 05:49 AM
by Anonymous User
Not applicable
Hi, I'm trying to connect to an Oralce 12c database with instant client and tnsname. I've installed the client, configured the TNS_ADMIN variable, created the tnsnames.ora file and I've set the path variable to read the x64 client before the x86, however, when I try to connect to the db from Arcmap I obtain the error: ORA-12154: TNS:could not resolve the connect identifier specifiedNo extended error.
The tnsname.ora file is correct, since I have connected successfully in sqldeveloper using the same alias.
Does anyone have any suggestion?
Thanks
by Anonymous User
Not applicable
Thank you everyone, I have solved the issue by creating the folder network/admin in the instant client folder and copying the tnsnames.ora file into that folder. Now it works, so I think it was due to a wrong configuration of the tns_admin variable (I will investigate about this).
MichaelVolz
Esteemed Contributor
What is the exact Oracle version that you are trying to access?
by Anonymous User
Not applicable
Oracle Database 12c Enterprise Edition Release 12.1.0.2.0 - 64bit
JonathanFarmer_oldaccount
Hi Vincenzo,
I'd suggest you look at / try a couple of things here:
  1. If you want to rule out an issue with TNS Names, try connecting using the EZConnect syntax instead. If this works with nothing else changing then we know there is an issue with TNS Names in some way.
  2. Make sure you are using a 12.1.0.2 client so that it matches your Oracle instance. Since you are connecting to ArcMap, you only really need the 32 bit client. But if you need the 64 bit client as well to use Pro or Server, just make sure it is listed before the 32 bit which I think you already have.
  3. Make sure the TNS configuration string is in TNSNAMES.ORA file of 32-bit Oracle client. ArcMap can't use information from the 64 bit client so they need to match here.
If you can connect fine from SQL Developer (which I presume is a 64 bit install on your machine?) then I would guess the issue is related to the 32 bit client in some way. We just need to narrow it down a bit more.
One more thing, this isn't related to your issue but you may be interested in installing it, we have a patch for 10.5.1 for some Oracle issues. See more below:
Esri Support ArcMap 10.5 (10.5.1)
Jonathan
AndresCastillo
MVP Regular Contributor
In my organization, I had issues connecting to the database from my local machine, but not from a server
ERROR:
ORA-01034: ORACLE not available
ORA-27101: shared memory realm does not exist
Linux-x86_64 Error: 2: No such file or directory
Additional information: 4376
Additional information: 344321215
Process ID: 0
Session ID: 0 Serial number: 0
http://www.dba-oracle.com/sf_ora_27101_shared_memory_realm_does_not_exist.htm
The reason that local machines seem to get the error connecting to the DB is because the centralized management directory server stores network address tnsping details using SERVICE_NAME still rather than SID, which is preventing local machines/vdi's access to the DB.
This is revealed by comparing tnsping results from local machine vs from server machine.
https://docs.oracle.com/database/121/NETAG/config_concepts.htm#NETAG003
The DBA can fix this configuration in the directory server, or alternatively, reconfigure tnsping details back to SERVICE_NAME.
by Anonymous User
Not applicable
Thanks for the update Vincenzo. Glad you got it sorted out!
Jonathan
arahman_mdmajid
Faced it too and placing the tnsnames.ora file in the /network/admin folder resolved the issue.
Another thing to note here is that, you will need to place the file in both, 32 and 64 bit clients to connect to the desired database in ArcMap and ArcGIS Pro respectively.
Abdur Rahman
GIS Developer
