ArcGIS Server + Web Adaptor possible problem
340
03-13-2025 03:07 AM
HellisPelizzari2
Hi all,
I have an issue with ArcGIS Server and Utility Network.
I have a server where ArcGIS Server and Web Adaptor v11.3 + all patches are installed.
When I navigate the service via the Web Adaptor, some requests seem to randomly fail. The map updates partially, and many errors appear in the console.
In Chrome:
Failed to load resource: net::ERR_CONNECTION_RESET
In Firefox:
There are no errors in the console, but some requests show NS_BINDING_ABORTED, and others have 0 bytes transferred.
However, if I access the services using the internal port 6443, this issue does not occur.
Could it be that the Web Adaptor sometimes drops connections or encounters errors if the machine is under heavy load?
ChrisUnderwood
Hello @HellisPelizzari2 , the error message and symptoms you have described seem to match the defect reference BUG-000168562.
https://support.esri.com/en-us/bug/arcgis-web-adaptor-may-stop-responding-to-requests-when-bug-00016...
ChrisUnderwood
RyanUthoff
MVP Regular Contributor
Are there any status updates for this bug? We are looking to upgrade from 11.2 to 11.3, but are hesitant because we don't want to encounter this bug as it would have a pretty big impact to our end users.
The support article you posted said this happens when the web adaptor is "under load", but that is a very relative term. I was wondering if there is a more specific definition of "under load", or had any specific examples of when this happens "under load." We're trying to get a feel if it is "safe" for us to upgrade to 11.3 or not.
omar-marji
I ran into this issue as well and was wondering if anyone was able to resolve the issue.
I don't think that "under load" is really a correct term to use here, as I can consistently reproduce this issue by just zooming in and out 3-4 times on one map with just one user.
