ArcGIS Server Publishing Problems
2958
12-03-2014 08:39 AM
JonathanMori3
I worked with the IT Department of our company to set up ArcGIS Server on a VM. We are using 10.2.2 Server Advanced with Windows Server 2008 R2.
ArcGIS Server is set up with Active Directory.
I have yet been able to successfully publish a Map Service without receiving an error.
The two Errors Below are the ones I intermittently receive.
I also have this error in the Server logs, but I checked multiple times and my username is included as a Publisher and an Administrator.
The service is not visible when I load the Services Directory.
"Failed to compute the privilege for the user 'LUMOSNET\morij'. java.rmi.UnmarshalException: Error unmarshaling return header; nested exception is: java.net.SocketException: Connection reset"
