ArcGIS Server - how to change coordinate display from decimal degrees to lat long.
741
10-22-2020 05:13 AM
StewartGalloway
New Contributor III
Coordinate widget no eye iconArcGIS Server - I want to display lat long instead of decimal degrees.  I have a Web map application with the live coordinates located at the bottom left of the map.
DavidPike
MVP Frequent Contributor
Hi Stewart,
If you go into your widget controller on the web app, edit the 'coordinate' widget - this should give you a choice of units and display order.
StewartGalloway
New Contributor III
Dave,
Thanks for the help. I found that and changed it. However, now the “eye icon” has disappeared which makes the widget useless.
Any suggestions would be appreciated,
Thanks.
Stew
DavidPike
are you saying the widget/corner coordinate bar now can't be made visible by clicking on the eye?
what CRS is your basemap in?  Have you got any pics?
StewartGalloway
New Contributor III
The coordinates are visible but the eye icon is not. I was able to use the icon before I changed the coordinates.
CRS is UTM.
