ArcGIS Server Feature Service not adding to map in Edge Browser
1452
01-19-2017 07:18 AM
AwesomeEvan
For some reason I cannot add a public feature service to an arcgis online map, in the edge browser. Even working directly with the rest endpoint. All other browsers seem to work!
Water_Distribution (FeatureServer)
When I try opening clicking on View In:   ArcGIS Online map viewer ...
It works in all browsers except Edge which gives the error "The layer, Water_Distribution, cannot be added to the map.
If you do not see the same perhaps its restricted to a local network issue?
Thanks for any help.
Cheers
RandallWilliams
I don't see this in my environment, using Edge on Windows 10 build 1511. If you'd like to capture the session with a tool like Fiddler or similar, I can have a look at your network traffic. You can remove any sensitive URLs you might not want to share.
JeffreyHolden
New Contributor III
We are having this problem with a number of application.
JeremyLyman
New Contributor II
Yes, the map viewer is unable to load my custom tiled basemap services, and fails to open any maps. I can't edit or create anything!  This was working fine two weeks ago.
RandallWilliams
If you press f12 when this issue happens, what errors do you see in the browser console?
DougKampe
New Contributor III
I spent days trying to figure out why our internal REST services wouldn't display on AGOL. Originally, I thought there was a permissions issue, but I got the bright idea to try Chrome and TAADAA! everything worked as expected.
AGOL basemaps display, I search and add layers on AGOL, but I cannot add our own REST services using edge. It only works on Chrome, Firefox, or Explorer.
