ArcGIS Server fails to show the Map services even though the server is working fine.
Despite the fact that the ArcGIS Server is working fine, it fails to show the map services when i try to view/consume it.
For example, I tried to publish map service “parcel_02” & when I try to consume this service it fails to appear. Attached
What might be the issue here?
I used ArcMap & ArcGIS Server 10.5
Best,
Rawan
Dear Jayanta,
I tried to republish the service with no advantages. Attached
Best,
Rawan
What is the third warning from the analysis that is covered up in your snapshots above? Does it have anything to do with reference frame v's data reference system being different? Maybe the data is not projecting correctly when publishing. That may account for the extent (XMIN YMIX XMAX YMAX) all being null or NaN.
if not, it still may be that although you mxd has permissions to the data, maybe the ArcGIS Server service does not. Can you look at the permissions on the folder and source dataset? Use file explorer, not catalog, to look at the security properties.
Dear Rebeca,
the ArcGIS server also have a full control on the data source. the data frame & the layer has the same reference system.
Yes Neil I published the map service in all scales.
Just a quick check, but when you look at the REST service, have you tried clicking on the View In option and looked at it using the ArcGIS JavaScript viewer? You can at least confirm the features are viewable.
Yes I tried this option, and nothing was able to appear.
Just confirming - you have ArcGIS Desktop 10.5 and ArcGIS Server 10.5. Is that correct?
I'd make sure there isn't an issue with publishing the map service in 10.5.
This is the first time I face this issue.
I will try to publish it by using Arcgis pro, is that will be related to my issue?
Best,
Just a test to see if you are able to publish with Pro and then use the REST service. 10.5 is fairly new, so I'd test to make sure a problem hasn't been introduced with this release.
