Arcgis Server Error
1690
10-02-2020 05:15 AM
Muhammet_İkbalYaşar
We constantly get the attached errors in the logs of our Arcgis Server server.
  • This exception was thrown after the response was committed. Not Found
  • Response already committed. Cannot forward to error page.
Do you have any idea about this?
ElliotJones
Hi @Muhammet_İkbalYaşar,
Is ArcGIS Server behaving normally otherwise? If not, what behaviors do you see around the time these log messages are generated?
This is a fairly uninformative error, so unless there are functional problems it might be hard to pin down the root cause.
suryakanthjayavarapu
Please check the below log errors after two times of 9001 error code 9002 log is registered multiple times please suggest.
Oct 4, 2023, 12:39:30 PMThis exception was thrown after the response was committed. Access to this resource is not allowedRest9002
Oct 4, 2023, 12:39:30 PMResponse already committed. Cannot forward to error page.Rest9001
pp
Got this same message today, and we are using Geocortex Essentials, the problem is that when using Geocortex to gcreate new features nothing happens and this message remains in arcgis server. How to fix the issue?
