ArcGIS Server Connection Times out or won't connect in ArcMap
3656
06-11-2015 05:57 AM
NathanPugh
New Contributor III
I am trying to create a connection to an ArcGIS Server within ArcMap but it will not work.  I keep receiving various error messages: unspecified.png or
I know the server and services are running because I can access them through the rest endpoints and via the ArcGIS Online Map.  Any help would be appreciated.
JakeSkinner
Esri Esteemed Contributor
Hi Nathan,
What type of connection are you trying to create (User, Publisher, Admin)?  What version of Desktop are you using to make the connection?
NathanPugh
New Contributor III
Jake,
I am trying to create a user connection within ArcMap 10.2.0.3348.
JakeSkinner
This should work in 10.2.  I was able to successfully connect using 10.3, but unfortunately I do not have a 10.2 instance to test with.
JayantaPoddar
MVP Esteemed Contributor
Hi Nathan,
Remove "/services" from the connection string and try again. I hope you are using valid credentials for making the connection.
Think Location
RebeccaStrauch__GISP
I'll assume you know your proxy is set up correctly?
Are you using a web adapter, and it is the default "arcgis" or another name.    I get the error is I use arcgis (we have two web adapters, neither is arcgis).  I agree with Jaynata that the word "services" could be left off, but it will add it on after.
try    https://<your url>/<webadaptrer>/rest/services
You can also connect directly to the server machine (assuming you are within you firewall)
  • http://<your server>:6080/arcgis
    • notice http.....but you will only get unsecure folders/services
  • https://<yourserver>:6443/arcgis
    • notice https....you will still only get unsecure folders/services if you don't provide required credetials
If, like us, you have to change your password every 60 days or so, I highly recommend you do NOT "save username/password".  If you don't remember to change the password in the connections each time you password changes, it can do nasty things like lock you out (and it's not always easy to track this issue down, if you have a lot of connections.....take it from experience...ugh).
Just some of my suggestions.
