ArcGIS Server 10.7.1 Feature Service Layers don't display in ArcGIS Pro 2.8.2
1906
8
09-08-2021 02:48 PM
JoeBorgione
As the subject line suggests:  when I add a feature service layer from an arcgis server 10.7.1 to Pro 2.8.2 the features will not display.  They show up in the TOC and the attribute tables are fine.  A colleague using a Pro 2.7.x install gets them to display just fine, as I did at that version.
Has anyone else experienced this?
That should just about do it....
Tags (1)
DanPatterson
MVP Esteemed Contributor
DanPatterson
so zoom to layer doesn't work or adding it to an empty map (with no other data)
... sort of retired...
JoeBorgione
Correct.  I don't see the features; I've tried points lines and polygons.
@DanPatterson here is what it looks like:
DanPatterson
right-click zoom to layer....
I just saw your gif opening the table
JoeBorgione
I did that too... Nothing shows...
DanPatterson
JoeBorgione
Isn’t that just duckie.
DanPatterson
thankfully I was bored 😉   amazing the number of bugs associated with web stuff
("feature service layer", Bugs, newest to oldest .... 86 Esri Support Search-Results )
JoeBorgione
I’m looking forward to some solid boredom. But between now and the end of the year I’m scrambling to keep the latest greatest technology from hemorrhaging too much on the bleeding edge.
