ArcGIS Server 10.7.1: Caching an orthophoto fails to produce all required levels and ends up with a warning,
587
01-03-2022 10:01 AM
JamalNUMAN
Legendary Contributor
In the screenshot below, the cache configuration is set to produce 13 levels. The caching stops at L08.
What could be the issue here?
Jamal Numan
MichaelGinzburg
Occasional Contributor II
Is it possible you're out of space on the C: drive?
JamalNUMAN
The area of the imagery that’s needed to be cached is really small while there is plenty of space in drive C as per the screenshots below
What other settings\issues I might need to consider here?
Jamal Numan
JamalNUMAN
Formatting the machine and installing ArcGIS 10.9.1 resolves the issue
Jamal Numan
