ArcGIS Server 10.5 - Identify (MapServer)
1013
08-16-2021 04:46 AM
TasadduqHussain
New Contributor III
In ArcGIS Enterprise 10.5,when i publish Map service through database (Oracle),identify not shown values on my map click.
Any solution will be highly appreciated
Thanks
DavidPike
MVP Frequent Contributor
via what means are you consuming the service e.g. Pro, arcmap or Portal etc? If it's a Web Map it may be as simple as enabling popups https://doc.arcgis.com/en/arcgis-online/reference/configure-pop-ups.htm
https://doc.arcgis.com/en/arcgis-online/create-maps/configure-pop-ups-mv.htm
TasadduqHussain
New Contributor III
I am using ArcGIS Enterprise10.5 Map Service.
TasadduqHussain
New Contributor III
Issue facing screenshot.
George_Thompson
Esri Frequent Contributor
I just posted in your other post about this: https://community.esri.com/t5/publishing-and-managing-services-questions/popup-not-shown-results-thr...
Also may want to look at upgrading the Oracle geodatabase also to supported version, if it is 10.0 currently. I do not think that will fix the issue, but would not hurt.
--- George T.
