I'm getting an error every 3-5 weeks on my ArcGIS server and I can't find an questions/articles anywhere which talk about this error in regards to ArcGIS server. The error is similar to below:
"There is an error drawing the layer: <INSERT LAYER NAME HERE>"
Which is, in the same second, followed by the error:
"There is an error during the draw <INSERT LAYER NAME HERE>(1.) General function failure [<INSERT SOURCE DATATABLE NAME HERE>]"
I'm not sure what is going on here. If I restart the server these services all work again and everything is fine for quite some time. I can't pinpoint exactly when things started to go wrong but this problem never happened in previous versions of Arc Server. If I open the originating MXD then everything is drawing fine as well.
I must note that the services which are failing have the maximum number of instances running as shown in Arc Catalog and the ArcGIS sever manager web page.
Does anyone know what's going on here?
