ArcGIS Server 10.2.2 : Incorrect minPixelSize and maxPixelSize from JSON REST
827
08-10-2014 09:29 PM
MarkChilcott
Hi Peoples,
We have installed ArcGIS Server 10.2.2 on our test instance, and just found the minPixelSize and maxPixelSize have been reversed in the JSON REST.
This is a cached image service.
Our 10.1.1 image service is here, and is correct:
http://services.thelist.tas.gov.au/arcgis/rest/services/Basemaps/Topographic/ImageServer?f=pjson
     "minPixelSize": 0.5971642835598172,
     "maxPixelSize": 9783.93962049996,
On our current TEST server, ArcGIS 10.2.2, this is the same service:
"minPixelSize": 9783.93962049996,
"maxPixelSize": 0.5971642835598172,
Note this is incorrect.
Has anyone else seen this?  Is it a known issue?
Our initial tests would indicate some third party apps rely on this, and it is going to be an issue.
Cheers,
mark
MarkChilcott
This has been recorded as a bug:
#NIM104376:
The JSON response of a cached image service shows wrong 'minPixelSize' and 'maxPixelSize' values in ArcGIS Server 10.2.2
Although a bug, not sure if third party apps are relying on this information too much, so probably not a big issue.  Also seems to be for cached image services.
Cheers,
Mark
