ArcGIS Portal 10.6.1 Living Atlas Tab not working
2264
9
08-17-2018 06:52 AM
XiaoyiZhang1
We updated our portal from 10.5 to 10.6.1 recently. We found the Living Atlas Tab does not work when you click. But the contents of Living Atlas are still there when searching for them.
Anyone has similar issues?
RandallWilliams
Is the content still shared with the Living Atlas portal group?
XiaoyiZhang1
yes.
The Living Atlas contents can be searched and used. But clicking the Living Atlas Tab did not return anything
DanielCota1
Hi Xiaoyi Zhang
Have you taken a look at the following documentation? Upgrades to Portal 10.6.x will require that you upgrade Living Atlas content as well from Organization > Edit Settings > ArcGIS Online. From here, click Upgrade Content
(FAQ) - Upgrade your ArcGIS Enterprise portal—Portal for ArcGIS (10.6) | ArcGIS Enterprise
(How-To) - Upgrade your ArcGIS Enterprise portal—Portal for ArcGIS (10.6) | ArcGIS Enterprise
I hope this helps.
-Daniel
XiaoyiZhang1
I did ArcGIS Online Update Content steps and still not working.
JeffSmith
Can you reproduce this issue in multiple browsers?  I've seen some issues when using IE 11 to access parts of the Portal Home app and I'm wondering if that might be related to what you are seeing here.
XiaoyiZhang1
I have tried IE11, Chrome, and Firefox. They are all not working.
JonathanEscobar
Hi Xiaoyi Zhang ‌
I wanted to let you know that i'm working with someone on the same issue you've been seeing and will give you an update when I have a more details.
Talk to you soon!
XiaoyiZhang1
thanks
CheickDiarra
Is there any update on this issue? Thanks.
