ArcGIS Notebook Server: Windows does not support CPUPeriod
1167
11
04-30-2019 01:02 AM
I'm having issues running ArcGIS Notebook Server 10.7 on Windows Server 2019 (Version 1809).
Firstly, the ArcGIS Notebook Server installation guide: https://enterprise.arcgis.com/en/notebook/latest/install/windows/install-docker-for-arcgis-notebook-... recommends to install Docker Desktop for Windows, however Docker Desktop for Windows is only supported on Windows 10. After installing Docker Desktop on Windows Server 2019 I was unable to switch Docker to use Linux containers. So I uninstalled Docker Desktop and installed Docker EE following: https://bcthomas.com/2019/02/getting-started-with-linux-containers-on-windows-server-2019/. Then I've followed the Notebook Server installation guide, importing the standard and advanced images using postInstallation utility and federating ArcGIS Notebook Server site with ArcGIS Enterprise base deployment.
Now, there is another issue. Opening the Notebook web UI from the portal website I get this error: Windows does not support CPUPeriod.
Do anybody have a clue how to solve this?
Matej
Reply
Occasional Contributor II
FYI - answered here https://community.esri.com/thread/239463-how-to-install-docker-desktop-on-windows-for-notebook-serve.... You need to use Docker Desktop 2.0.x not the current release of 2.1.x.
Reply
Hi Angus,
yes. Docker 2.1.x can be installed on 2019, but not 2016. For windows 2016, you will have to use a previous 2.0.x version of Docker Desktop for Windows.
Reply
