ArcGIS Enterprise SSO
686
12-04-2023 08:30 AM
FeelingMappy
Hello, I have integrated my AD with enterprise successfully and achieved SSO by disabling anonymous access. This however does remove the option for a named user outside my organisation to sign-in.
Is this behavior expected? I was hoping for SSO for my internal organisation users, and the normal named user sign-in for users outside the organisation.
Thanks!
Scott_Tansley
MVP Regular Contributor
Most organisations use SAML2 rather than IWA for that sort of use case.
You cannot have anonymous and IWA in place at the same time.  It's self-defeating from a security perspective.  So, if you use IWA then all users will be challenged for a login, and you would need to provision an AD account for your external users.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
