Greetings. I am working in an offline environment with ArcGIS Enterprise 10.9. I am accessing the server with a web app using the JS SDK, and the mapping portion is working fine. I have enabled CORS for my origin in Organization->Settings->Security. However, now I've needed to access the fonts served by the server, and I've changed the font url to https://myserver.com/portal/fonts but I get a 500 error response when the SDK tries to grab the fonts and the console error says that CORS is not enabled. Is CORS for the fonts endpoint of the server enabled elsewhere? Is there another solution?
Thank you!
