ArcGIS Enterprise 10.7.1 - Issue with replica and offline area (Collector)
1400
08-21-2019 12:54 AM
NicolasGIS
I am trying the new Collector for ArcGIS and the capibility to configure offline area directly in the webmap but I face an issue: every time I try to download the map from Collector, the download failed with the following error:  "Download Failed".
I activated logging from Collector and saw the following error:
“Replica with GUID ({ac5c8afc-2aa3-4fb5-b767-b3231c2337c6}) does not exist on the server” – “Unable to complete operation”. I have the same error from Federated ArcGIS Server Manager interface.
I thought there was an issue with the service configuration or with the database but I can download the very same map when defining the offline area directly in Collector.
Using Fiddler, I was able to see that the “createReplica” operation was not made the same way as the old Collector:
POST to myAGSservice/FeatureServer/createReplica
I understand that the new Collector is using the replica made while creating the offline area and does not find it but it does exist in our database:
select  a.UUID, a.NAME, a.PHYSICALNAME, a.PATH, a.DATASETINFO1,a.DATASETINFO2,
b.NAME, (timestamp '1970-01-01 00:00:00 GMT' + numtodsinterval(SUBSTR(a.PATH,8,20)/1000, 'SECOND')) at time zone 'Europe/Paris'  "REPLICA_DATE"
from GDB_ITEMS a join GDB_ITEMTYPES b
on a.TYPE = b.UUID
where datasetinfo1 is not null and b.name in ('Sync Replica', 'Replica') and a.UUID = '{AC5C8AFC-2AA3-4FB5-B767-B3231C2337C6}' order by REPLICA_DATE
UUID
NAME
PHYSICALNAME
PATH
DATASETINFO1
DATASETINFO2
NAME
REPLICA_DATE
Ags_Fs_1566310546195
SCHEMA.AGS_FS_1566310546195
https://hostname.company.com:6443/arcgis/rest/services/myservice/FeatureServer
username@company.com
Sync Replica
20-AUG-19 04.15.46.195000000 PM EUROPE/PARIS
Looking at the output from the database query, I noticed that Portal for ArcGIS is registering the replica with the private url (https://hostname.company.com:6443) and Collector is trying to download it from the public Url configured with the webadaptor (https://hostalias.company.com).
If I do the very same request to “createReplica” endpoint with the same parameters but this time to the private Url (https://hostname.company.com:6443), it works.
Is it a bug or is something misconfigured with our ArcGIS Enterprise ? Any idea maybe  Jonathan Quinn‌ ?
If I go to the Portal for ArcGIS sharing REST end points:
https://myportal.company.com/geoportal/sharing/rest/portals/0123456789ABCDEF/servers
I have the following output for the federated ArcGIS Server:
    "id": "anId",
    "name": "hostname.company.com:6443",
    "adminUrl": "https://hostname.company.com:6443/arcgis",
    "url": "https://hostalias.company.com/arcgis",
    "isHosted": false,
    "serverType": "ArcGIS",
    "serverRole": "FEDERATED_SERVER",
    "serverFunction": "GeneralPurposeServer"
Thanks for your help,
NicolasGIS
Thanks for the reply Jonathan Quinn‌.
Indeed, just contacted Tech Support and here is the NIM:
"BUG-000124867: When attempting to download a managed map area in Collector for ArcGIS, the download fails due to an error that occurs between ArcGIS Server and the ArcGIS Web Adaptor replica access"
Workaround: "Add the layers associated with the map to Portal for ArcGIS through the :6443/arcgis/rest URL instead of the Web Adaptor URL."
JonathanQuinn
Esri Notable Contributor
I believe this is a bug. Unfortunately, I don't have the bug number on hand, but reach out to Tech Support who can work on attaching you to it.
NicolasGIS
