ArcGIS Enterprise 10.5 backup with WebGIS DR - Failed to generate the ArcGIS Server token from the portal
3658
12
09-27-2019 08:13 AM
AlessandroValra
I need to do a full backup of an AGE 10.5 using the WebGIS DR tool.
The final aim is restoring it on a different machine as described in the guide Migrate to a new machine in ArcGIS Enterprise using the WebGIS DR tool
My server OS is Windows 2008 R2 64bit.
I am following Create an ArcGIS Enterprise backup—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise.
I have configured my webgis.properties file (called "webgisdir_BAK.properies"), and then I launch from the CMD the command:
   webgisdr --export --file "C:\Program Files\ArcGIS\Portal\tools\webgisdir\webgisdir_BAK.properies"
Unfortunately, I receive the following error:
   Failed to generate the ArcGIS Server token from the portal https://svksi058a.globalnt.it:7443/arcgis/sharing.
   Failed to get the configuration of the web GIS.
   Stopping the webgisdr utility
I attach the encrypted "webgisdir_BAK.properies" and the "webgisdr.log".
I also tried to set the ArcGIS Server to HTTPS Only and have my Web Adaptor allowing administrative access as suggested in Portal Backup with webgisdr: Server is not started, but still I had no luck.
I also opened a case to Esri meanwhile but as this is an important operation, I wanted to post my problem here to see if I had more chances to solve it.
Thanks in advance.
AlessandroValra
I successfully exported the server and portal sites with the exportSites methods in the same folder where I would have placed the output of the webgis dr without problems...
AlessandroValra
Harrold Sompotan
given that mine is just a migration to a new machine and the deployment is very basic with few (3) users, would you suggest going with these methods?
In my opinion, they seem rather straight forward, although I never tried them.
Thanks in advance for any advice.
AlessandroValra
Replying to myself. I tried the export/import site from one machine to another and I had issues because in the new machine I came up having a Portal federated with a server with the hostname of the old machine. I managed to fix it but this is of course a good method to recover from a disaster but not to migrate...
