ArcGIS DataStore 10.9.1 - Configuration Wizard page not loading
1041
11-25-2021 03:29 PM
AnthonyRyanEQL
Occasional Contributor III
Hi all,
I have just done a clean installed ArcGIS DataStore 10.9.1 on Windows 2016 server. The install went as expected.
A browser launched to go through the configuration wizard (https://localhost:2443/arcgis/datastore/) but came up blank. I looked at the debugger tools and noticed a javascript error on bootstrap.js
Has anybody else come across the type of error before?
Thanks
AnthonyRyanEQL
For some weird reason the configure url now works
Scott_Tansley
MVP Regular Contributor
Not sure it's a fix, but I never use localhost when I'm configuring anything in ArcGIS.  I'll replace the localhost with the fully qualified domain name of the host.
Also with your hosting server, have you federated this already?  If so are you configuring the data store with the Primary Site Administrator, and is that still enabled?  if you've federated then could be a reason for token errors.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
AnthonyRyanEQL
Scott,
Thanks for the tip. I use to swap localhost for the server name back in 10.3.1 and forgot all about it. Gave that a go and same result. Looks like i'll be putting in a support ticket.
Thanks again
AnthonyRyanEQL
