ArcGIS Data store's folder pg_xlog size increase 16MB every 5min
3444
01-23-2018 10:09 PM
ImtiyazPasha
After further investigation we found E:\arcgis\arcgisdatastore\pgdata\pg_xlog folder size keeps on increasing and at this moment consuming 322 GB.
For every 5 minutes, it creates one file of size 16MB. Is this any log file? but the portal log is at E:\arcgis\arcgisportal\logs folder.
Is there any relation between E:\arcgis\arcgisdatastore\pgdata\pg_xlog  and E:\arcgis\arcgisportal\logs\database\pg_log?
 Please view the attached files.
Below are Operating system details.
Operating System: Windows server R2 standard (64 bit)
RAM: 16 GB
Processor: Intel(R) Xion® CPU E5-2683 v3 @ 2.00Ghz 2.00Ghz
ArcGIS Tool: ArcGIS Enterprise Builder(10.5.1) including patches.
Thanks in advance.
ImtiyazPasha
We got it.
Culprit is ArcGIS DataStore:
ArcGIS Data Store’s E:\arcgis\arcgisdatastore\pgdata\postgresql.config file  contains “archive_command”.
archive_command = 'C:/Program^ Files/ArcGIS/DataStore/framework/etc/scripts/dbcli put-transaction-log "E:/arcgis/arcgisdatastore/pgdata/%p" "%f" "C:/Program^ Files/ArcGIS/DataStore/"'
We didn’t install the ArcGIS Data Store at 'C:/Program^ Files/ArcGIS/DataStore and
we installed at 'E:/DataStore.
Why ArcGIS Data Store is considering 'C:/Program^ Files/ArcGIS/DataStore’ as our ArcGIS Data Store  installation folder?
We changed the “archive_command” as below and restarted the ArcGIS Datsore service.
archive_command = 'E:/DataStore/framework/etc/scripts/dbcli put-transaction-log "E:/arcgis/arcgisdatastore/pgdata/%p" "%f" "E:/DataStore/"'
ArcGIS Datastore started deleting or truncating old log files E:\arcgis\arcgisdatastore\pgdata\pg_xlog files.
At last, problem solved.
RandallWilliams
This sounds like a permissions issue on the PG_DATA directory. Those logs should be truncating. Under the 'tools' directory, run configureserviceaccount.bat. Here's the syntax:
configureserviceaccount [--username username] [--password password] [--readconfig user-configure-file] [--writeconfig user-configure-file\
http://enterprise.arcgis.com/en/portal/latest/administer/windows/data-store-utility-reference.htm
You also might want to look into your backup creation and retention schedule.
ImtiyazPasha
Hi Randall,
No folder named  E:\Datastore\logs or  E:\Datastore\nosqldata but we have
E:\arcgis\arcgisdatastore\logs and E:\arcgis\arcgisdatastore\nosqldata.
Best regards,
Imtiyaz
ImtiyazPasha
We got it.
