ArcGIS 11.3 web-hosting under nginx are we required web-adaptor
431
04-07-2025 11:12 PM
riteshpurbey
Hello 'El,
Please confirm: For ArcGIS 11.3 web hosting under NGINX, is the Web Adaptor required? What will be the NGINX virtual hosting configurations?
As of now we've setup below
1. Web-server
2. Portal
3. Data-Store + Server
Note: Using Ubuntu 22.04 OS.
Best Regards,
RP
Tags (1)
JeffSmith
Hi @riteshpurbey
Yes, you can use NGINX on your web server without a web adaptor.  That will work fine.  NGINX will need to listen on port 443 and you'll need to define a unique "location" directive for both Portal and Server and proxy to ports 7443 and 6443 respectively.  Make sure to include the X-Forwarded-Host header as well that matches the hostname of the web server.  Here is an example:
location /portal/ {
    proxy_http_version 1.1;
    proxy_pass https://example.domain.com:7443/arcgis/;
    proxy_set_header X-Forwarded-Host "nginx.hostname.com";
location /server/ {
    proxy_pass https://example.domain.com:6443/arcgis/;
You will also need to define the "WebContextURL" system property for both Portal and Server.  More information on that can be found in the help doc.
