Attached screenshot is ImageServer service with MosaicSet with 2 rasters in same folder!
the top one is SID
and Bottom is ECW.
As you can see it's displays as checkers (black and white)
Any suggestion?
@Dvirus wrote:Hi,
the top one is SID
and Bottom is ECW.
Any suggestion?
https://community.esri.com/t5/arcgis-enterprise-questions/mosaic-dataset-as-map-service-black-and-wh...
As for the black/white checkerboard, this indicates the imagery could not be found by the server. Since it happens when you zoom in, it sounds like the server has access to only the overviews, but not the source imagery. Do you have the source directory registered with the server's data store and did it validate? While we're at it, since you do have the extension, what happens if you publish the mosaic dataset as an image service rather than a map service? Do you still see the issue with image service?
Thanks for reply,
I think that overviews are generated as Tiff (I checked the folder content) and that why in some of scale (the very first ones) are showing.
Any suggestion why it's happen?
As per ESRI Tech Article https://support.esri.com/en/technical-article/000010516, A ECW plugin and "To use ECW in server-based products requires additional licensing permissions from Hexagon AB, who acquired ERDAS, Inc., the inventors of the ECW format.".
Search for the plugin download - https://download.hexagongeospatial.com/search?keyword=ecw&lang=en
