Arcade- '$Map Not Defined' inside Popup expression
1689
06-04-2025 11:04 AM
SteveCole
Honored Contributor
I'm clearly missing something here. Using Portal 11.3 and, for a map layer's popup content, I've added an Arcade Expression Block. When I attempt to access the $map profile variable inside that Arcade code block, Arcade barks and says that it's not defined. Through searching the forum, I did find a discussion about the variable profile context and that $map is only defined (available) in certain situations. I feel as though it should be accessible from where I'm trying to reference it. But clearly it's not.
The only $ profile variables available to me are $feature, $graph, and $userInput
Steve
SteveCole
Honored Contributor
Figured it out, and I don't believe this is documented (but I could be wrong). The layer I was using in my map was a MapServer service instead of a FeatureServer service. If I tried this with the FeatureServer service, I see the $ variables I would expect to find.
I was using the MapServer option because of the desire to preserve some hatch symbology used on a layer with M values. The more you know...
SteveCole
Honored Contributor
MichaelVolz
Esteemed Contributor
So does your response mean you need to access the object via a feature service as opposed to the mapservice?
