"Method failed.HRESULT = 0x80070057 : The parameter is incorrect" in AGS 10.1 log
41828
23
12-07-2012 09:33 AM
TomCohen
I have several map services running on the same server / AGS instance and one of them, which sources all its data from File GeoDatabases (which are registered folders on the server) periodically logs the following message in AGS (tagged SEVERE).
The service is configured to always draw data dynamically, and has never been configured to create / use a tile cache. However, it also periodically logs
Failed to rename cache folder
This message is also tagged SEVERE. There doesn't seem to be any issue rendering data, and rendering time is good, so I have no idea if this is a problem or not.
Any suggestions on what's going on here would be much appreciated.
GabiVoicu
Two more versions pass by and sure enough coming across exact same error in ArcGIS Server 10.3
The service looks fine in the rest point as well as the query on a certain layer but the app does not display this one layer in particular from the service that throws this error ...it's not consistent either ...
It's been a while since this post was started - is anyone else is seeing this error in 10.3 ?
Thank you
ChrisJensen
I am getting this error in 10.3.1 while trying to publish an editable feature layer, followed by 'Failed to rename cache folder' error
GerardEddy
Is this still an issue for anyone?  Has anybody come across this error in relation to  a Dynamic Service?  There is no cache associated with the service.  Niels' links were dead ends.  one was a 404 error, the other gave a "site error" and informed me the administrator was notified.
Was/Is this a known bug with respect to dynamic services?
Thanks all, in advance.
AndyBradford
I'm getting this error, and it seems to be causing a service publish to fail. We have a third-party SOE that has to be enabled in the service's Capabilities to function, and this error message appears as it's failing. It works if the service is pushed without the SOE, but if I enable it it fails.
KarenFolger
I am getting this same error publishing at 10.5.1. I made sure that my ArcGIS Server Service account had all the permissions to the Cache folder and all the other arcgiserver folders and that they were not read-only. I re-published several services and got this same sequence of errors on every service. They are dynamic feature services from a file geodb on the same server. The services do work but excessive logging concerns me. All errors are SEVERE:
Failed to rename cache folder.
Method failed.HRESULT = 0x80070057 : The parameter is incorrect. . - for the Source service - this msg shows twice.
ApurvDanke
I am also having the issue as given below in ArcGIS Server logs.
In my case, I have a web service which calls the "ExportMap" method of ArcGIS Server REST API for a particular dynamic map service to generate a map image for a given extent. In few cases such as mentioned above, the web service fails to generate a map image because of the errors mentioned above in ArcGIS Server logs. When I checked the same scenario again, the image was retrieved successfully and generally it works. It is these one off cases where I've observed that it fails. I am using ArcGIS Server 10.4.1. Any suggestions?
Regards,
Apurv
CesarAlvear
Encontré la solución aquí, en mi caso funciono..!
The solution here.!
BLOG DE CMAV: Method failed.HRESULT = 0x80070057 : The parameter is incorrect. .
TaraPreston
Hi Cesar. Do you by chance know if this has been translated into English anywhere? Thanks.
davehorsey1
Hi Tara. Open the link in Chrome and it'll translate the page for you.
This error code and message can also be seen in other applications. Has anyone in the thread tried to do the registry tweaks mentioned in this article - Error Code 0x80070057 - Causes and Methods to fix it | Fix Errors
Change you make to the registry are done at your own risk, etc, etc
DaveSivertsen
This link is no longer valid. Anyone care to post the solution that used to be there?
We have this issue as well.
Thanks.
