Method failed.HRESULT = 0x80070057 : The parameter is incorrect
Failed to rename cache folder
We have the same problem. Services producing these entries in the log files but in our case, it did affect the service. The service could be viewed from the rest endpoint but none of the layers were available.
Here's the error description from 10.1 help:
http://resources.arcgis.com/en/help/main/10.1/index.html#//00vp00000033001499
Description
The cache folder gets renamed prior to being deleted. That rename process has failed. The cache folder may be open in some other window. Some other application may currently be consuming the cache folder. The cache folder could be set to read-only.
Solution
Make sure that the service cache directory and its folders are not open in any other program or window and that they are not read-only.
Is it possible that the permissions for the cache directory maybe set up incorrectly? The Arcgis server administrator group would need read/write permissions.
Hi
the cache rename error is a known bug
http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDg5MTY2
regard, niels
niels - the URL you provided appears to be in a password-protected beta testing area. Are you able to extract and post some text? I am currently dealing with the same issue...
Sorry about that
I searched for this issue while i was logged in.
The result without login is
