AGS10.1 - Failed to create service "System/CachingTools.GPServer"
8684
17
06-15-2012 12:17 PM
BerndMareth
during site creation with ArcGIS for Server Enterprise 10.1 (final) I get the following error:
Failed to create the site. Failed to create the service "System/CachingTools.GPServer".
(also see attachment)
Is this a known error and does anybody know a solution? (the log file also only contains this error message and provides no further details)
Bernd
AndrewCox
Bernd,
I am getting exactly the same error. Did you manage to find a solution to this?
Regards
Andy
AndrewCox
Bernd,
Did you have the pre-release installed on the machine before you tried to install the final release? The only reason I ask is I've just installed the final release on a new machine and the site creation worked fine.
I think the only difference between them was I had previously installed the pre-release on the machine where the site creation failed.
Andy
BerndMareth
The only solution i have is to uninstall and reinstall ArcGIS for Server 10.1 - on some machines this helped (but I had to do it for a few times).
Pre-release was not installed - but ArcGIS 10 was (on some machines Desktop+Server, on some only Desktop).
Bernd
nicogis
MVP Frequent Contributor
Have you details in log?
What's the international settings in your computer?
BerndMareth
No, the log file shows only the same error message like the browser - notthing else.
Normally it is German, but I also tried English (US) as mentioned in another thread.
IainCampion
re: 10.1 new out of the box install no pre release
I've had this same issue and it appears to work if you turn back the security to
Configuration Settings
User Store: ArcGIS Server Built-in
Role Store: ArcGIS Server Built-in
Authentication Tier GIS Server
Authentication Mode: ArcGIS Tokens
I had it connected to the domain accounts ... which would have been better to manage.
errors were
Error executing tool.: ERROR 999999: Error executing function. Unidentified Error Failed to execute (ReportCacheStatus).
Could not retrieve cache job details to fix.
System/CachingTools.GPServer failed to process request.
The containing process for 'System/CachingTools' job 'j9521a6ac2823441da5a2806712ecc040' has crashed.
ChristophSpoerri
I'm having the same problem with 10.1 Release.
I tried to solve the problem (as suggested by Bernd) by reinstalling the server, but no luck. Yet, when I tried to connect to the manager after the failed setup of the site, the admin interface came up anyway. But I noticed, that the directory 'config-store\services\System\CachingTools.GPServer' was missing.
Any idea what's going on here?
Chris
MarcelFrehner
please consider the following technical article about Windows firewall configuration:
http://support.esri.com/en/knowledgebase/techarticles/detail/40465
The steps outlined do apparently help in some, but unfortunately not all cases.
Regards, Marcel
BubbaHey
