After upgrade ArcGIS Enterprise for Portal from 10.8 to 10.8.1
801
07-30-2020 07:54 AM
GerPha1
There a mysterious user (admin??????) created inside Portal and it can't be remove. Is this normal or did something happen during upgrade process that require the account to be create?
JonathanQuinn
Esri Notable Contributor
Apologies, I mispoke and updated my initial comment. You can reindex the portal and it should go away.
JonathanQuinn
You can delete that account. It's created to do some intermediary work during the upgrade and was leftover in the index as an oversight. Run a user reindex via the Portal Administrator Directory and that will get rid of the user.
GerPha1
Jonathan,
I used the portal admin account that was created during installation process to delete but got this error message "You do not have permission to access this resource."  I check at the portal admin interface and the account "admin695930" does not exist there. Is there any other way to remove this unwanted account?
JonathanQuinn
GerPha1
Thanks Jonathan that works.
