After an upgrade from Enterprise 10.6 to 10.6.1 my services will not map.
1195
08-14-2018 05:49 AM
TraceyMcPherson
Single machine install
Server 2012 R2
Had a few services created that worked in 10.6
After the upgrade:
- no services will map
- Can create new services with ArcMap 10.6.1 and ArcGIS Pro 2.2 just fine but... unable to add to a map.
Error
The layer, Layer Name, cannot be added to the map.
Checked the logs on verbose
No entry, no error
Can someone please enlighten me??
Just in testing phase with Enterprise, not impressed.
Tracey
George_Thompson
Esri Notable Contributor
How did you upgrade the single machine, i.e. use Enterprise builder or individually?
What components are on the machine (Portal, Server, DataStore, 2 WA etc.)?
Any errors during the upgrade?
Any other information that you can provide would be helpful. Thanks!
--- George T.
TraceyMcPherson
Tracey
Ausable Bayfield Conservation Authority
George_Thompson
Tracey McPherson‌ Unfortunately it looks like noting came in via your post? Can you copy/paste into a reply?
--- George T.
TraceyMcPherson
George,
Looks like the server web adaptor had not been configured after the upgrade. Works now.
Thanks !
Tracey
George_Thompson
That is great news to hear. I would always recommend following the upgrade documentation workflow for ArcGIS Enterprise: Upgrade ArcGIS Enterprise—ArcGIS Enterprise | ArcGIS Enterprise
It may cut down on the issues encountered.
--- George T.
