access map and feature services on arcgis enterprise for kubernetes
640
01-05-2026 05:29 AM
Martijnde_Boer
When arcgis enterprise is installed on-premise with rancher kubernetes in 1 namespace and there is in another namespace with a custum application that only need to access to map and feature service.
Is it possible to access those map/feature services within the kubernetes cluster? tru the internal kubernetes ingress controller to -> https://organization.example.com/<context>/rest/services
VenkataKondepati
Honored Contributor
Yes, but you should avoid "hair-pinning" your traffic out to the public Ingress just to come back in. Since both apps are in the same Rancher cluster, your custom app should talk to ArcGIS Enterprise using the internal Kubernetes Service DNS (e.g., https://arcgis-service.arcgis-namespace.svc.cluster.local/...). This is faster and bypasses external load balancer latency. Just keep two things in mind: first, ensure your custom app's pod trusts the Root CA used by Enterprise, or you'll hit SSL handshake errors; and second, check that your Network Policies actually allow cross-namespace traffic between your app's namespace and the ArcGIS namespace.
Regards,
Venkat
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
VenkataKondepati
Honored Contributor
Regards,
Venkat
Martijnde_Boer
Hi Venket, thanks for the answer
Is this solution also supported bij Esri?
regards
