A method to check how our services are healthy
8581
43
07-08-2017 11:33 PM
rawansaleh1
Occasional Contributor III
I couldn’t figure out if there is a method to check how our services are healthy.
For example, I need a tool to send a notification for me if one of my services are stopped suddenly or any failure happened to my services.
I need any method to make a periodic check on my services.
Any suggestion for that?
Best,
Rawan
Tags (1)
rawansaleh1
Thanks Xander for sharing the above python, that’s will be helpful
I will try it to see if this works with me or not.
Best,
Rawan
rawansaleh1
When I tried this python on another server I got the following error, what might be the issue here?
XanderBakker
Esri Esteemed Contributor
The error message indicates the some security setting is preventing the script to access the folder with the log files. Work with your IT people to obtain the proper read access on the log files.
rawansaleh1
Thank you xander, I will check this and update you.
rawansaleh1
Thanks Jonthan,
We hope that ESRI provide us such a tool (not out from the box) to help the users in tracking their system.
Best,
Rawan
by Anonymous User
Not applicable
Hello Rawan,
I have an script which will fulfill the necessary task for you.
Avinash Patel
rawansaleh1
Dear Avinash,
May you please share the script to test it on my environment?
Best,
Rawan
rawansaleh1
Dear Avinash,
Do you still have the script?
Best,
Rawan
AlaaFlaifel
Dear Avinash,
Can you please share your script with us?
Alaa
by Anonymous User
Not applicable
Hi Alaa,
I am working on this using ArcGIS rest API probing and share you soon
