Hello,
We just installed ArcGIS Server 10.2.2 (AGS). The service account on AGS is a domain account that is also within our SQL Server database (operating system).
We have tried several ways to create 2-way disconnected replication using Operating System Authentication.
Our main users (who are Publishers in AGS and hoped to make replica owners, set up database connections, etc) are set up on SQL Server as follows:
Server role is public
Mapped to the database in SQL as db_datareader and public
Membership at the database level is db_datareader
Privileges given via ArcCatalog to the data layers is SELECT, INSERT, UPDATE, DELETE for their operating system logins
However, when they tried to create geodata services and replicas, the remote user could see the data using their AGS built-in user name and password BUT the sync would not work UNLESS we gave the AGS service account db_owner membership at the database level. I would have thought this unnecessary for the service account. Because setting db_owner for the service account seemed like a security risk, we are currently using database authentication for setting up replicas, geodata services and database connections and it works.
This database user is set up this way:
Mapped to the database in SQL as public
It does not have any Membership at the database level
It does have its own schema at the database level.... (I tried doing the same with the service account OSA but it didn't seem to make a difference)
Privileges given via ArcCatalog to the data layers is SELECT, INSERT, UPDATE, DELETE for this database user
My questions:
Thank you in advance,
Amy Rose
Solved! Go to Solution.
In case anyone else has this problem: Spoke with ESRI Tech support. You have to use database authentication with disconnected replication...
Problem solved!
Problem solved!
