Upgrade portal 10.5 to 10.6.1 on linux Centos Server fail
390
08-01-2019 08:36 AM
GuillaumeArnaud
I see this issue : Upgrade Portal from 10.5.1 to 10.6 fails but it's on a Windows server.
I think I have the same but on a Linux CentOs 6 Server : lc_collate values for database "postgres" do not match:  old "fr_FR.UTF-8", new "en_US.UTF-8" (full log in quote)
I ask french support but I don't have any answer so I try there.
I have a snapshot of the 10.5 portal so I try many things : Reindex, recreate the initial administrator account (We destroy it because we use an LDAP to log in) but nothing to do.
I try to upgrade to 10.5.1 and it works but not between 10.5.1 to 10.6.1.....
Also, I save my portal with websigdr and restaure it on a new config (CentOs 7). I have the same issue...
Do you have any idea to help me to get around the problem or to solve the issue ?
Many thanks !
<Msg time="2019-08-01T16:43:33,970" type="INFO" code="209076" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Backup completed for db, content and index folders.</Msg>
<Msg time="2019-08-01T16:43:33,972" type="INFO" code="209038" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Starting the migration process from 10.5.0 to 10.6.1.</Msg>
<Msg time="2019-08-01T16:43:33,973" type="INFO" code="218032" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Cleaning Index Service config files.</Msg>
<Msg time="2019-08-01T16:43:34,15" type="INFO" code="209063" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Upgrading the database from 9.3.12 to 9.6.8.</Msg>
<Msg time="2019-08-01T16:43:34,15" type="INFO" code="209039" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Starting the 9.3.12 database.</Msg>
<Msg time="2019-08-01T16:43:40,192" type="INFO" code="209040" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Get the initial database install super user.</Msg>
<Msg time="2019-08-01T16:43:40,300" type="INFO" code="209041" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Stopping the 9.3.12 database.</Msg>
<Msg time="2019-08-01T16:43:46,841" type="INFO" code="209064" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Stopping the database.</Msg>
<Msg time="2019-08-01T16:43:53,437" type="INFO" code="209081" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Postgres DB upgrade response Performing Consistency Checks
Checking cluster versions                                   ok
Checking database user is the install user                  ok
Checking database connection settings                       ok
Checking for prepared transactions                          ok
Checking for reg* system OID user data types                ok
Checking for contrib/isn with bigint-passing mismatch       ok
Checking for roles starting with 'pg_'                      ok
Checking for invalid "line" user columns                    ok
Creating dump of global objects                             ok
Creating dump of database schemas
  gwdb
  postgres
  template1
                                                            ok
Failure, exiting
.</Msg>
<Msg time="2019-08-01T16:43:53,439" type="SEVERE" code="209044" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Upgrade failed. com.esri.arcgis.portal.admin.core.site.migration.MigrationException: Failed to upgrade the PostgreSQL from 9.3.12 to 9.6.8. com.esri.arcgis.portal.admin.core.site.migration.MigrationException: Failed to upgrade the PostgreSQL from 9.3.12 to 9.6.8.</Msg>
<Msg time="2019-08-01T16:43:53,440" type="INFO" code="209072" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed="">Starting migration rollback process.</Msg>
<Msg time="2019-08-01T16:43:53,444" type="VERBOSE" code="219999" source="Portal Admin" process="18055" thread="15" methodName="" machine="SIGD-ARCGIS-PORTAL-2" user="" elapsed=""> Copying the content directory.</Msg>
GuillaumeArnaud
After many tries changing rights on files, folders... Moving files on other server, save and restore portal full... I think I found how to do...The owner of Portal need to be in the sudoers and when I use sudo ./upgradeportal.sh -s it seems works.
JonathanQuinn
Esri Frequent Contributor
There shouldn't be a need for the install user of Portal to be in the sudoers group, especially for an error that implies a locale problem:
https://stackoverflow.com/questions/52539100/why-did-this-postgres-database-upgrade-fail
I'd suggest you reach back out to your Support team and have them escalate to Esri Inc. if necessary.
