Symbol Display
865
11-02-2011 09:23 AM
RobCox
I have created a Symbol Line to indicate a Force Main Line.  When the segments are short, the arrow symbols on the line show up to the side.  Is there any way to remedy this problem?
SimonKettle
Occasional Contributor III
A quick fix is to convert to graphics and move the features.
This is only a temporary solution and if you need to edit it in the future you'd need a better fix.
You can also play around with the scale or line thickness and other features in the symbology tab...I have had a similar issue when drawing thrust fault lines where the thrusts symbols (a solid triangle on a line) detatch a look silly.
Bo_King
Bo_King
You may want to investigate the more robust Representation Rule symbology...
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//008t00000002000000.htm
