Scale Bar, adding a midpoint to every subdivision instead of just the first subdivisi
680
04-13-2012 07:07 AM
AndrewLawrence
Bit of a stupid question I guess, but I'm trying to duplicate a scale bar template printed on transparent plastic given to me. The original has a midpoint marker between every subdivision but I can only find the option to include the first midpoint on the version of ArcGIS 9.3 I am using. Does the option exist to have a midpoint marker between every subdivision and I'm just not seeing it? Thanks!
MarcinGasior
It would be great if you post an image of the scalebar you exactly mean.
I guess you can simulate midpoints by changing divisions and subdivisions number in 'Adjust width' resizing mode.
Mayby this examples would be helpful:
Both have the same settings in 'Numbers and marks' tab:
[ATTACH=CONFIG]13503[/ATTACH]
1. Standard scalebar:
[ATTACH=CONFIG]13502[/ATTACH]
[ATTACH=CONFIG]13504[/ATTACH]
2. Scalebar with adjusted number of subdivisions:
[ATTACH=CONFIG]13505[/ATTACH]
[ATTACH=CONFIG]13506[/ATTACH]
