In the layer properties, you can st the symbology to be "unique values, many fields." Each combination of the fields you choose (up to 3) can be assigned a different symbol.
I tried that actually but it still doesn't let you color each point with the RGB value combination for each point. All you can do is assigning a different symbol for each combination loaded from the available color palettes. Of course I could edit each symbol for all the combination, but that would take lots of time. I was wondering if you could assign the RGB values automatically. It's easy to do in raster but not for point files it seems.
I too, am having this issue. I have seen numerous posts/threads with this issue but I have never seen a solution. I'm assuming there Is a way to automate this is Python, but unfortunately I have little experience programming.
