Remove Users via code Portal 10.5.1
552
12-26-2018 08:35 AM
RoberthSanchez
New Contributor III
Hi, I need delete users from portal (previously added with LDAP) via code, i can see there is a way to remove users using the web service https://domain.com/arcgis/sharing/rest/portals/xxx789ABCDEF/removeUsers but only works to remove built-in users, not for enterprise users added with LDAP. There is a way to remove this kind of users via code?
i'll be gratefull if anyone can help me.
Thanks.
JeffSmith
Hi Roberth,
This can be done through https://portal.domain.com/arcgis/sharing/rest/community/users/*username*/delete where *username* is replaced with the enterprise username you are trying to delete.
RoberthSanchez
New Contributor III
It Works!.
BTW: i found that if i try to delete a user via POST with this service and the user does not exist, the message that return is wrong:
{"error":{"code":403,"messageCode":"GWM_0003","message":"You do not have permissions to access this resource or perform this operation.","details":[]}}
Thanks for your help Jeff.
