Publishing GDB as Hosted Layer Hangs
571
05-14-2019 09:40 PM
MatsHardy
I have setup a Portal 10.5.1 Server A and ArcGIS Map Server 10.5.1 B months ago. I have federated Server B to Portal A and serve as hosting server. Then I have succeeded to publish shapefile, gdb, etc on Portal A.
But last week, the publish is failed, Portal A just hung at publishing process without prompting any error messages. When I checked the log on Server B, I found that Server B kept on waiting geoprocessing service PublishingTools.
<Msg time="2019-05-14T17:44:14,39" type="FINE" code="8521" source="Server" process="1116" thread="14" methodName="WebSecurityManager.authenticate" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">HTTP Referer: http://www.esri.com/41D517B2-805E-4706-BBCF-702F35502B04</Msg>
<Msg time="2019-05-14T17:44:14,36" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Posting response from worker thread.</Msg>
<Msg time="2019-05-14T17:44:14,41" type="INFO" code="9502" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">Request received from the user '0123456789ABCDEF::ckmwong1@FEHD' for the service 'System/PublishingTools.GPServer'.</Msg>
<Msg time="2019-05-14T17:44:14,42" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="3628" thread="204" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request type = GetJobStatus - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,42" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Sending request to worker thread - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,41" type="DEBUG" code="9504" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Looking up GIS service 'System/PublishingTools.GPServer'.</Msg>
<Msg time="2019-05-14T17:44:14,42" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="3628" thread="204" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Delegating request to GPServer - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,42" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Waiting for response from worker thread - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,41" type="DEBUG" code="9999" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Binary request for service - System/PublishingTools.GPServer</Msg>
<Msg time="2019-05-14T17:44:14,42" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request received in worker thread.</Msg>
<Msg time="2019-05-14T17:44:14,44" type="INFO" code="9526" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request for the service 'System/PublishingTools.GPServer' processed successfully. Response sent to the user '0123456789ABCDEF::ckmwong1@FEHD'.</Msg>
<Msg time="2019-05-14T17:44:14,43" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Posting response from worker thread.</Msg>
<Msg time="2019-05-14T17:44:14,545" type="FINE" code="8521" source="Server" process="1116" thread="14" methodName="WebSecurityManager.authenticate" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">HTTP Referer: http://www.esri.com/41D517B2-805E-4706-BBCF-702F35502B04</Msg>
<Msg time="2019-05-14T17:44:14,547" type="INFO" code="9502" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">Request received from the user '0123456789ABCDEF::ckmwong1@FEHD' for the service 'System/PublishingTools.GPServer'.</Msg>
<Msg time="2019-05-14T17:44:14,547" type="DEBUG" code="9504" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Looking up GIS service 'System/PublishingTools.GPServer'.</Msg>
<Msg time="2019-05-14T17:44:14,547" type="DEBUG" code="9999" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Binary request for service - System/PublishingTools.GPServer</Msg>
<Msg time="2019-05-14T17:44:14,555" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="3628" thread="204" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request type = GetJobMessages - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,555" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="3628" thread="204" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Delegating request to GPServer - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,556" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Sending request to worker thread - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,556" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Waiting for response from worker thread - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,560" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request received in worker thread.</Msg>
<Msg time="2019-05-14T17:44:14,561" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Posting response from worker thread.</Msg>
<Msg time="2019-05-14T17:44:14,562" type="INFO" code="9526" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request for the service 'System/PublishingTools.GPServer' processed successfully. Response sent to the user '0123456789ABCDEF::ckmwong1@FEHD'.</Msg>
<Msg time="2019-05-14T17:44:14,563" type="FINE" code="8521" source="Server" process="1116" thread="14" methodName="WebSecurityManager.authenticate" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">HTTP Referer: http://www.esri.com/41D517B2-805E-4706-BBCF-702F35502B04</Msg>
<Msg time="2019-05-14T17:44:14,566" type="INFO" code="9502" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">Request received from the user '0123456789ABCDEF::ckmwong1@FEHD' for the service 'System/PublishingTools.GPServer'.</Msg>
<Msg time="2019-05-14T17:44:14,566" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="3628" thread="204" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request type = GetJobStatus - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,566" type="DEBUG" code="9504" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Looking up GIS service 'System/PublishingTools.GPServer'.</Msg>
<Msg time="2019-05-14T17:44:14,566" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Sending request to worker thread - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,566" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="3628" thread="204" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Delegating request to GPServer - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,566" type="DEBUG" code="9999" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Binary request for service - System/PublishingTools.GPServer</Msg>
<Msg time="2019-05-14T17:44:14,566" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Waiting for response from worker thread - System/PublishingTools.GPServer.</Msg>
<Msg time="2019-05-14T17:44:14,568" type="INFO" code="9526" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request for the service 'System/PublishingTools.GPServer' processed successfully. Response sent to the user '0123456789ABCDEF::ckmwong1@FEHD'.</Msg>
<Msg time="2019-05-14T17:44:14,567" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Request received in worker thread.</Msg>
<Msg time="2019-05-14T17:44:14,567" type="DEBUG" code="9999" source="System/PublishingTools.GPServer" process="7928" thread="20" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">Posting response from worker thread.</Msg>
<Msg time="2019-05-14T17:44:14,619" type="DEBUG" code="9999" source="Server" process="3628" thread="1" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="" elapsed="">A JSONObject text must begin with '{' at character 0 of </Msg>
<Msg time="2019-05-14T17:44:15,69" type="FINE" code="8521" source="Server" process="1116" thread="14" methodName="WebSecurityManager.authenticate" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">HTTP Referer: http://www.esri.com/41D517B2-805E-4706-BBCF-702F35502B04</Msg>
<Msg time="2019-05-14T17:44:15,71" type="INFO" code="9502" source="Soap" process="1116" thread="34" methodName="" machine="DGISMAP103W2K8.FEHD.HKSARG" user="0123456789ABCDEF::ckmwong1@FEHD" elapsed="">Request received from the user '0123456789ABCDEF::ckmwong1@FEHD' for the service 'System/PublishingTools.GPServer'.</Msg>
I have tried to reboot Portal A and Server B but no use. Anyone has ideas?
